EduardoMSerrano
- Oct 12, 2013
Hi all,
I'm thinking on building a new PC this Christmas and would like to know your opinions.
The PC is to be for both gaming and working (I'm a software developer). Furthermore the PC is going to be water cooled and overclocked.
Here are my plans so far:
_______________________________________________
CORE
CPU: Intel Haswell Core i7-4770K
MOTHERBOARD: Asus Maximus VI Formula
GRAPHICS CARD: EVGA Nvidia GTX 780
STORAGE: Samsung 840 Series Pro 256GB
MEMORY: Corsair Dominator Platinum 16GB 1866 (2x8)
PSU: Seasonic X-850 850 Watt
CASE: CORSAIR Obsidian 900D
MONITOR: Dell Ultrasharp U2312HM
WATER COOLING PARTS
CPU WATERBLOCK: XSPC RayStorm CPU WaterBlock - INTEL
GPU WATERBLOCK: XSPC Razor GTX Titan / 780
PUMP: XSPC Laing D5 Vario Pump with 3 Pin Tacho Cable Single Edition
PUMP TOP: EK Water Blocks EK-D5 X-TOP CSQ - Acetal
RADIATOR: XSPC RX360 Triple Fan Radiator
RESERVOIR: XSPC Photon 270 Tube Reservoir
TUBING: XSPC High Flex White
QUICK DISCONNECTS: Koolance QDC (New) Push Connect, No-Spill
FANS Scythe 120 mm 1450 RPM Gentle Typhoon (to be used for push-pull setup on the radiator)
I'm definitely a noobie and I welcome all input. My main doubts are:
1) Regarding the graphics card, should I go for a Superclocked or Classified version? Since I'm going to water cool the graphics card it isn't worth going
for any of those right? I guess I can overclock it myself...
2) Regarding the memory, maybe they cost too much for the performance they offer. Meaning I could get similar performance at lower cost or even better performance at the same cost. The thing is I'm also planning on getting the Dominator® Platinum Light Bar Upgrade Kit (2x) for the looks. However, if you really think that this memory choice is not adequate, please advise me on a better one.
3) Is this PSU adequate? Am I overshooting on the wattage? I chose this one because I believe they are quite good and silent, and thinking that in the future I might add more stuff to my build, another graphics card for instance.
4) I really liked the 900D case but I think someone once said that with great features comes a high price and I'm not sure if I'm willing to pay that much for a case. Should I just open my wallet or you think I'm just jumping the 900D hype train?
5) The monitor choice was a compromise between the gaming, work and cost. The hardcore gamers will probably throw stones at me for suggesting an IPS monitor but I think for my casual gaming it's more than fine. Or am I wrong? Should I go for a different monitor?
6) This is going to be my first water cooling setup. I've researched a lot but I still have lots of doubts. For instance I still don't get very well the ID OD stuff. Can all of the components I've listed be put together? I was planning on using the Koolance QDC at every entry point. For instance: a couple at the in and out of the CPU block, another couple at the in and out of the gpu block and so on. Am I doing it wrong? I understand this greatly increases the cost since it will be quite a lot of QDCs but I do like the flexibility they give me.
7) Which kind of QDCs should I use? They have QD2, QD3 and QD4 series...
8) Which ID OD should I use for the tubing?
9) Can you advise me on how the water system should be set up? From your experiences what is the best order for the loop?
10) Is there anything coming out from now to Christmas that I should take into consideration?
Although those are my main doubts please point out any inconsistencies/improvements that could be done.
Thank you all!
CORE
WATER COOLING PARTS
Thank you all!
