So a while back ago I posted in regards to part picking and putting together an i7 based machine on the 1150 socket type. However, **** went down and the funding that I was planning on to use towards it had to be spent on house work and other things. Now after the holidays and somewhat recovering from that, the Skylakes and 1151 have come about.
I'm still on this Phenom II x4 940BE AM2+ based machine with a bottlenecked to hell MSI 970 nVidia based GPU and 4x2048 of DDR2 modules at 800MHz.
I don't stress OC much, only just a bit that would be fine on air based cooling as I am still somewhat wary of water based solutions. Paranoia if you will, pump failure, leaking, etcetra. (Granted air cooling has fan failure, but usually there won't be much in terms of damage in that regard as the HS still works semi well enough on idle/desktop to keep it from going too hot and if one were to wake up and find it you could address it.)
...though I am starting to get off topic here.
SO! Would it be a better idea to completely redo a selection build based on the new 1151s, or stick to the 1150s, as from what I have been looking at. The 4790K outperforms the 6700K/6600K baseline(s), and the only viable reason I would see to go that way is after the 'tock' is done and seeing if any improvements come from that aside from the DDR4 memory speeds... Though I guess the more PCIe lanes would be a nice thing... Even though I tend to just stick with single-card GPU setups. (Though I do dual-monitor at min. Main monitor for gaming and video playback, second for browsing, monitoring things, chat programs, etcetra.)
I'm heavy into gaming and emulation as a core, and that's why the IPC performance of that 4790k still looks very promising.
I was looking at;
4790k i7 Build
MoBo - http://www.newegg.com/Product/Product.aspx?Item=N82E16813130770
CPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16819117369
CPU HS - http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
RAM - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231606
OS SSD - http://www.newegg.com/Product/Product.aspx?Item=N82E16820147372
6600k i5 Build
MoBo - http://www.newegg.com/Product/Product.aspx?Item=N82E16813128880
CPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16819117561 (The i7 variant seems too much for me in this socket, though would still be nice.)
CPU HS - Same as 1150 selected above.
RAM - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231884
OS SSD - Same as 1150 selected above.
Was just going to move the GTX 970 into it after, along with the TX650W 80+Gold Corsair I have... though would probably be a good idea to replace the PSU at some point a swell. It's over five years of age itself, and has been mostly ran 24/7. Something modular, maybe.. be nice not to have wires just... there.
Any thoughts/suggestions welcome, especially if pricing can be cheaper on either direction.
I was looking at;
4790k i7 Build
6600k i5 Build
