- Dec 27, 2008
equifox, what reporting software are you using? I would try some different temp reporting utilities.
And if the water block came with various mounting hardware for different sockets, make sure you're using the correct screws/spacers/springs for your socket.
The other thing that would be interesting to try would be to temporarily remove the water block from the CPU socket and install an ordinary air cooler and see if your temps would normalize.
