Hey All,
Need your guys' advice - new build (first build as well), get to the point of turning it on and...nothing.
Spec details:
CPU: i6700
Cooler: Deepcool Gammaxx 300
Mobo: ASUS Z170-P
RAM: Kingston HyperX 2 x 8Gb
GPU: MSI GTX1060 OC 6Gb
Storage:
Kingston 240Gb SSD
Seagate Barracuda 2Tb 7200rpm
PSU: Casecom 750W
Case: Coolermaster Storm Stryker
So 1st time hook it all up, both mobo sockets power hooked up, GPU power hooked up, front I/O panel connected, back of PSU turned on, green LED on mobo is on...press power button on front I/O panel, the power light flashes for a second then goes off, but nothing else - completely dead.
Initial thought was that PSU was DOA, but mobo LED and flash on power switch suggests otherwise???
Did some reading and worked out I had a few unnecessary standoffs in the case, so took them all out to eliminate possibility of short, reconnected everything and same story - power light flashes for a second, disappears, and nothing else.
So removed all unnecessary stuff - disconnected power to GPU, removed one RAM stick and moved the other one to closest slot to CPU, disconnected all front panel except power switch and again, the same story...
At a loss here guys - need some wisdom...would appreciate your thoughts.
Cheers
Spec details:
CPU: i6700
Mobo: ASUS Z170-P
Storage:
Kingston 240Gb SSD
PSU: Casecom 750W
Cheers
