New Build (need advice)
DarkFuneral
sup guys...ive got a computer build im planning on putting together in the near future, and although ive done extensive research, i would still like to get more opinions on if the build will WORK...yes, there are a lot of components but thats the point, i like technicality, no minimalism...forget cost effectiveness...i dont want to hear " wayyyy overkill dude"....i know it's overkill, thats the idea, all i want to know is if it works...heres the list:
mobo- ASRock Fatal1ty P67 Professional i7/i5/i3| Rev B3
power supply- Thermaltake TR2 RX 1200W Silent Power Supply
CPU- Intel Core i7 2600K Quad
RAM- G.SKILL Ripjaws X Series (4 x4gb)
GPU 1- XFX Radeon HD6990 830Mhz
GPU 2- XFX Radeon HD6970 900Mhz
hard disk- SEAGATE BARRACUDA 1TB SATA/600
sound card- Creative SoundBlaster X-Fi Titanium Fatal1ty Champion
optical drive- ASUS 24X DVD Burner (x2)
card reader- Kingwin KWCR-901 All-in-1
HTPC SCREEN- Antec Multimedia Station Elite
HDD CASE- Kingwin SATA Hot-Swap Rack (for 2nd HDD)
HDD FAN- Evercool Cool Wheel Hard Drive Cooler HD-CW-SR
LIQUID COOLING- Larkooler Universal High Performance Complete CPU kit
NZXT BUNKER - USB Locking Device
fans- (10X) Cooler Master SickleFlow 120x25mm Super Silent Fan
fan controller 1- Scythe Kaze Master Pro 5.25
pump controller- Sunbeamtech Rheosmart 3 (running 3 pumps)
HDD COOLING BLOCK- Magicool Hybrid PRO Cu/Al HDD Liquid Cooling Block
GPU COOLING BLOCK- Koolance VID-AR699 Radeon HD6990 VGA
GPU COOLING BLOCK 2- Koolance VID-AR697 Radeon HD6970
chipset water block- Alphacool Universal RF 14 Smart Motion Chipset
COOLANT- PrimoChill ICE Non-Conductive Liquid Cooling Fluid
FLOW METER- Thermaltake Flow Tx Plus Flow meter with Temperature Indicator (x2)
RESERVOIR/PUMP 1- XSPC X2O DC-200 "Bay-Res" Pump/Reservoir Combo (x2)
RADIATOR- X-Flow Black Ice Pro II High Performance Radiator (x2)
TUBING- PrimoChill PrimoFlex PRO LRT Tubing 1/2"ID 3/4"OD with 1/8" Wall
FITTINGS 1-(X16) Bitspower Matte Black Diamond G1/4" Barb Fitting - 1/2" ID
RAD FAN PCB- (X1) 3-Pin Power Distribution PCB 6xWay Block
volume control- Coolermaster Musketeer 2
LIGHTING- Logisys Dual 12" Cold Cathode Kit-red
SOUND LIGHTING- Logisys 15in Cold Cathode w/ Sound Module
THERMOMETER- XSPC LCD Temperature Sensor (x3 strategically placed)
AIR CONDITIONER- Evercool Personal Computer Air Conditioner
THERMAL COMPOUND- Scythe Thermal Elixer High Performance Thermal Grease
DISPLAY- Alphacool Graphical LCD-Display
TEMP/CLOCK DISPLAY- Logisys 5.25" Full Color Thermal/Clock Control Panel
HDD CONTROLLER- Sunbeam Rheobus Fan Controller 5.25"
RAD FAN CONTROLLER- Noise Isolator Black Fan and Light Controller 5.25
...as well each fan and pump will be wired to a switch to shut it off completely when not needed as well as being wired to the controllers (dont complain)
...plus needed power/reset bulgin vandal switches.
keep in mind i will be crafting a fully custom case for the build out of aluminum/acrylic...
for people who question the 3 separate cooling relays...
1: goes to CPU.
2: to HDD and Chipset
3: GPU's
again, all i want to know is if it will work, i know it's overkill, i know half of it is not needed, and i know it's gonna cost me a couple grand $$$, i have it already all priced...no complaints, just does it work??? thanks :)
I'm not qualified to speak on cooling, but I'd make the following points:
  • Why the graphics card mismatch?
  • Bulldozer is due out soon, I'd wait and see how it performs vs. Sandy Bridge
  • You want an SSD, really, for an 'overkill' build. Or, a pair of them in RAID 0. The 1 TB HDD is fine for storage though.
  • Two DVD burners are pointless, unless you have a specific use in mind. No Bluray?
I'm always interested when people talk about custom cases, I look forward to your posting pics when it's done :)
PS: Welcome to the forums!
I've heard a few bad things about XFX's ATI cards in terms of quality and their support.
Sorry, i forgot about the SSD...OCZ Vertex 3 VTX3-25SAT3-120G 2.5" MLC. and im thinking im only going to need one if im using the HDD for storage.
This is build is going to take some time so i'll be sure to look into Bulldozer when it comes out.
I never got into blu-ray, im happy with DVDS.
and, bad reviews on the XFX? i wasnt aware...ive already decided to use the two Radeon cards in crossfireX (ive seen spectacular benchmarks with the 6990/6970 combo)...perhaps Sapphire or AMD?
