- Mar 16, 2011
- South East US
Just completed a new build (components listed at the bottom) and I am encountering some issues that I would like to be a little better informed about. After putting the system together, I installed the software/drivers in the following order. OS (Win 7 Premium x64), Update OS, mobo drivers (from included disk), wireless USB NIC adapter (latest driver when compared to website), graphics drivers (266.66 I believe from Nvidia Website), sound card drivers, Win Security Essentials.
After installing the netgear USB adapter I noticed that I was not getting a good signal from where I had it plugged into the mobo. I moved it to a USB slot right next to it and was met with a BsoD. After a reboot, I moved the adapter to a USB on the front/top of the case, and then back several times to the mobo USB slots to see if there was an issue with the USB slots. The system remained stable through about 15 usb disconnect/reconnects though (allowing each time for full connection).
I then installed Dragon Age 2, and got about 85% through with the install and was met with a "Installation Failed" error. I installed again and was successful but I am now having Securerom issues (I believe I know what that problem is being caused by).
I have run the Win Mem Diagnostic Tool with no errors reported, and the system has otherwise been stable. My questions are:
1) Am I on the road to a significant hardware failure, and if so
2) What should I be on the lookout for
3) Is there a way for me to stress test my system to look for a weak link
Thanks for reading my wall of text (my first post! woot)
i7-950 Bloomfield @ 3.06 gig (strangely @ 3.46 in mobo bios..I have not overclocked it)
Asus Sabertooth x-58 mobo
6 gig G-skill ddr3 (3x2 gig Triple Channel)
Thermaltake Frio CPU Fan
Seagate Baracuda 1 TB 7200 Sata 3gig/s OEM
EVGA Geforce 560ti 1 Gig
Coolermaster GX 750 PS
Coolermaster Storm Sniper Mid Tower ATX Case (1x120mm fan, 2x200mm fans)
LG Sata DVD Burner OEM
Win 7 Premium x64 OEM
