Hi
Need some help please.
I have the following:
X99E-ITX/ac USB 3.1 Intel Motherboard. BIOS 57MOXE10014
Cooler Master RC-1200-KKN1 Cosmos 2 USB 3.0, Hinged Side Panel, Ultra Full Tower Black
Corsair (CP-9020084-UK) RMi Series RM1000i ATXEPS Fully Modular 80 PLUS Gold 1000W Power Supply Unit
Kingston 32GB (16GB x2) DDR4 2400MHz Non ECC RAM Memory DIMM
Intel i7-5820K Extreme Hex Core CPU Processor 3.30GHz, 15MB Cache, 140W, Socket 2011-V3, 28 Lanes PCI Express Generation 3
Samsung 2.5-Inch 1 TB 850 EVO Solid State Drive
Zotac GC-XNGTX974, 4GB nVidia GeForce GTX 970 PCI-e 3.0 VGA Card
LG 16X BLU-Ray- DVD Writer
Windows 10 Pro
When I switch on I get no signal to VDU.
All the fans power up ok.
I have tested all the parts on another PC and all work fine. The only thing I have not tested is the CPU but I would get a beep error if faulty!
I have had a guy check my setup to make sure its connected up ok.
Motherboad replaced but get the same issue.
heard from someone that might be a compatability between motherboard and nVidia GeForce GTX 970 series.
thanks
josa
Windows 10 Pro
thanks
josa
