I feel like a dummy, but I did find the screw. It was in a separate bag from the rest of the screws, hidden away in a little compartment in the cardboard packaging of the motherboard.
Don't feel too bad, I just did the same thing last week.
Try them now...
[*]Senior Members are knowledgable, experienced and level headed members who have contributed greatly to the forums. These members have no moderating authority but are an important part of the forum staff - they are the link between the members and the moderators.
The "..." is when you just paste a url directly into the post instead of using "[url=" tag, the URL is truncated automatically in your post, but just for the label text. The actual URL is the same. The problem happens when someone tries to copy and paste this truncated label, then the copied URL will not be correct and will instead try to go to the truncated. I'm not 100% sure of which conditions cause the URL to be truncated (for example if you use the
Thanks for the input. That's helpful.
It is not time.
A quote from the Forums Guidlines
EDIT: That and your ability to keep the toilet clean.
Do they sell the full Windows 10 key for switching motherboards?
