If you know you are not going SLI, 850W is way too much.
500 would do. Or 550 if you want some overkill.
Well, they sell PSUs.
This one is recommended by many members here (including myself). I tested it with my system, compared to multimeter reading. It's fairly accurate and realistic.
http://extreme.outervision.com/psucalculatorlite.jsp
With that system at 4Ghz and an overclocked 480. You are looking at 500W or so. A 650W would truely be fine, but Im saying 750W to allow for ample headroom.
I would take the calculator's recommended wattage, and add 50W to it (even though the recommended wattage takes into account headroom already).
The calculator has option for SLI, too.
an overclocked 480.
Looks good to me.
Fans generally go into mobo.
