New case fan matching.
deathstar13
FSB FRIEK
They didn't really have RGB 25 years ago so im clueless and figured i better ask.
This is the case i bought and it comes with 5 RGB fans more.
I need 5-6 fans fans more just like whats in it.
Im planning on 3 forward and 3 reverse but not sure it the same fans. so it will be 6 total.
Also should i use Mobo fan headers or run 1 header to a fan hub so they star the same speed?
It's up to you as it depends how you want to control your case fans. If you want the same speed, throw it on a controller. If you want individual control, split them up and piggyback on some headers. Same advice from your build thread. ;)
im mainly ask if my fans will match and act the same as the ones the case came with. Do they look the same type?
But i get your point thanks!
Clearly, they don't look alike. I don't know their specs offhand, you'd have to look it up.
Id guess they are some no name china-brand fans on the no-name case. It's going to be tough to match...
....but again, look and see what they are (look on the hub for a model #) and try to find them.
The model number for the GameMax fan is FN12A- N2 and FN12A-N2-R (reverse). Hopefully that will help you locate matching fans.
Here's a review of the fans...
Seems the only US distributor is newegg & they don't have those fans on their site.
Thanks guys as that should put mje on the right track now. And no it wasn't obvious to me differences.
