- Aug 27, 2002
- The OCFORUMS
I love my current case, but its heavy, and steel. Steel and water dont mix. So im looking for an aluminum case. I want it to be similar to mine. What it needs:
120mm Exhaust in rear
Removable hard drive bays, with removable bracket via screws(most use rivets)
The little plastic dohickys that let you just slid your cdrom drives in and out.
Sleek look, either black or silver
BIG BIG BIG, need to fit chevette heatercore in the front
I was looking around newegg and found several that meet most of the requirements, but most dont have a 120mm exhaust, and use rivets. Otherwise I wouldnt be asking. So....whats a good case? Im kinda on a $100 budget.
