- Jun 25, 2003
- Southampton, UK
So it's pretty obvious that the key to good cooling in an air-cooled rig is good airflow (and a case that provides it). However, I never would have suspected that a new case would yield such a difference. Upon the advice given to me in this thread:
http://www.ocforums.com/vb/vb/showthread.php?s=&threadid=253594
I decided on the Aopen H700b. And I'm glad I did
When I first switched on my rig after moving it into this case, it was running almost 20c under its normal load temps. My old case was some crappy no-brand case that cost £30 (did come with a no-brand psu, though ).
The temp has since risen (I think the central heating came on), so my cpu load temp now maxes out at around 44c, which I consider a success when it was 55+c before (with the side panels off my old case).
I'm not sure how useful this is to anyone. I guess my point is get an Aopen h700b
