SOLVED New celery 600 Bad MoBo
S
Stealth
Guest
Just got a new celery 600 pre-tested to 1080. went to put chip in and the socket clips that hold the HF broke off on me, I have an Abit VH6-II and like it very much, don't want to have to replace it just yet. Any help would be appreciated greatly. Thanks Stealth
ive heard supergluing the tab back on works OK your not fished with that MB just yet :)
Oh and if that does not work and gluing a new tab on does not work for you you can get arctic silver glue and glue the HSF to your chip but this would be a last resort as it is permanent. If you dont want to wait or cant find arctic siver JB weld will wotk fine too.
goodluck
Thank all of you for all of your help, I tried the superglue idea tab broke in different spot guess it is just a weak socket. I was able to rig up a nice little thing using some massinary{?} twine 10 awg wire washers and a bolt, wish i could show yall a pic of this. Magiverism at it's finest.. Works just fine now 600 @ 949 105 FSB v @ 1.8 temp Idle 35c full load 39c room temp 31c. Yea i know to darn hot A/C not working properly.... Thanks for all your help,,,,,,,,,,,,,,,,,,,,,Stealth
