- Feb 14, 2002
- The Bad Lands
I am trying my hand at building my very first computer system today with the parts on hand... I would greatly appreciate some help on a few things that I am unsure about...
The following hardware are present now:
1. Antec 1040B server case with a 400 watt PSU.
2. Asus P4T-E MOBO
3. Audigy Platinum sound card
4. Plextor 24x10x40 CDRW
5. Iomega 250 mb Zip drive
6. 3.5" floppy drive
7. Logictech Z-560 4.1 THX certified subwoofer speaker system
8. Microsoft Internet Pro USB key board & optical mouse
9. 3Com 56 bit NIC card
10. Creative Labs full duplex voice, fax, data, V.92 56K modem
11. 80 mm Antec front case fan with small (3) pin connetor
12. Maxtor 80 gig 7200 rpm ATA-133 hard drive
13. Sony G410R 19" flat monitor
I am currently waiting upon my Intel 2.0 ghz CPU with 512 L2 cache & fan / heatsink, ATI 8500DV video card, 512 RDRAM w/ECC, and on Zip cartrige...
These are my Q's for you computer GURU's... Some of the peripherals came with molex connectors with a Y shaped (split) power distribution plug...
Q: Can I plug the first female connector to say the CDRW, and then the other female plug end to my Zip drive... Then on the male end of the (Y) plug inserted into the PSU???
Q:I have done the very same wiring to the HD & the 3.5" FD but have used the other PSU wiring harness to connect a (mini 4) pin molex connector to the FD for power in the back... <---- Is this correct???
Q: There is also a (2 wire) blue & black "small" molex connector coming out of the Antec PP-412X 400 watt PSU... Where does it go on the Asus P4T-E MOBO???
Q: There is also a (6 wire) 3 black, 2 orange, 1 red colored "large" molex connector coming out of the PSU... Where does it plug into???
There are (2) rear Antec case fans each of them have (2) large male & female plug ends...
Q: Do the two case fans simply connect to one another, then I take another PSU power supply harness and connect to it??? Or would I plug each case fan into it's seperate PSU power harness???
Q: The front fan is a 80 mm Antec dual ball bearing case fan... This fan has a very "small" 3 pin molex connector... Where the heck does this plug into??? I did notice on the MOBO that there is a similar 3 pin connector labeled (PCI FAN JEN). Could this be used for the front fan??? Because there are no other similar plug jacks coming out of the server case PSU that would terminate into it...
There are (5) front server case wires for the following things:
POWER SW, RESET SW, SPEAKER, POWER LED, HDD LED...
I have found the corresponding pins on the Asus P4T-E mobo on the lower right side of the board just below the DIP switches for FSB overclocking features...
The MOBO is labeled as this (TOP ROW): MLED, SMI, PWRBTN, RESET...
The lower portion is labeled: PLED, KEYLOCK, SPEAKER...
Below is what the pins look from above to me: There are 10 rows of these dual (2) pin connectors that look like this= ::::::::::
. . . . . . . . . . <---- This is the top row labeled I think withe the words written below the pins.
Q: Do they simply plug into the board horizontal, or vertical???
I would greatly appreciate any and all positive feed-back in this matter to find a happy ending to this drama...
Thank you very much one and all...
Regards
Teken
2. Asus P4T-E MOBO
Regards
Teken
