New computer build...how to fdisk n format?!
jeff_harrison_344
Senior Member
I jus put together a new computer...>XP1800...WD 40 giger...anyways....any disk I put in and boot with...it just says ATAPI CD-ROM BOOT:
DISK BOOT ERROR, REPLACE THE DISK WITH A SYTEM DISK THEN PRESS ENTER
this is with the XP boot disk and the ME one.....all I need is to run fdisk then format but i dont know how now??? Anyone??
Kendan
Senior Punk
Dark side of hell
Get the WD disk utility from there site then put it on a floppy and start it that way you will be able to set it up just fine. Boot disk.com is good too.
specific
Atlanta, GA
That thing is beautiful. The WD utility disk is amazing. I don't know why it works when nothing else will, but it's simply wonderful.
J
jeff_harrison_344
Senior Member
Well the bootdisk one didnt workl....same thing:(
I went to WDs site...but dont knoiw wut to download....could someone point me to what I need to dload??
thanks again
J
jeff_harrison_344
Senior Member
Nah I already checked that and its set to boot on floppy first...then CDROM....thats why i am so confused
Im guna try the WD thing
J
jeff_harrison_344
Senior Member
Alright well this got even more weird.....I found out that I connected the floppy to the MOBO but not to the power....so i figured ok itll work now....the green light is on the floppy and all....and i turn it on.....baM same thing?! Has anyone ever had this before
repo man11
If the light on the floppy is allways on, then the cable is 180 degrees off. The light should come on briefly, and go out.
J
jeff_harrison_344
Senior Member
Well now its reading the drive...thanks a lot guys
but now ....Disk I/O Error....Replace the disk and press any key
repo man11
Hmmm, not having much luck tonight are you?
I'd guess bad floppy, bad format, or possibly a bad drive.
Which one are you trying to use?
The Dr. DOS file is an executable, you have to run it by double clicking, and it will load to a floppy. Just in case you didn't know, I don't mean to insult your intelligence.
J
jeff_harrison_344
Senior Member
Ok...Finally got it working...just needed a little bit of floppy disk tweaking
Thank you so much guys whenever i have a problem I can always count on you
