- Jul 11, 2007
Hey sorry this has to be my first post, definitely not going to be my last here hehe as I plan on overclocking my comp.
Okay first I will state my problem then the parts my comp is running on.
I am pretty sure I have stuff hooked up correctly but I may be wrong, hopefully theres an easier answer to my problem. When I start up my PC after everything is hooked up all my LEDs, on my water block, my fans,and the main power LED all power on but have a constant blink to them and my GPU (8800 Ultra) the fan ticks along with the LEDs blinking but never really starts up (the fans are blowing and the pump is doing its job but I'm pretty sure they are all doing the pulsing but since its not visual like the LEDs I cant really tell). My computer fails to boot at all and just sits there blinking until I hold down the power button until it turns of. I'm thinking about resetting my CMOS but I'm not sure if that will work. Also I'm wondering if its the fact that my board says it supports 1.8v DDR2 ram but my Crucial Ballistix sticks (4x1024megs) are rated at 2.2v 1066mhz. From what I know (a bit) it should auto clock down to DDR2 800 and run fine at 1.8v as all the reviews I have read about the mother board are using 2.2v ram. Other than that I really am out of ideas and I don't want to take it to some "supposedly expert" PC technician just to break/tell me something is broken when its probably not. Basically my comp doesn't Post or Boot.
Also I can upload a video somewhere for stream or post it on filefront if anyone wants to see exactly what it is doing. Just let me know.
Case: ThermalTake Kandalf LCS
Mobo: GA-N680SLI-DQ6
-----http://www.gigabyte.com.tw/Products...spx?ProductID=2460&ProductName=GA-N680SLI-DQ6
Processor: Intel QX6700
GPU: 1x PNY 8800 ultra OC
PSU: Thermaltake Toughpower
Ram: 4x Crucial Ballistix 240-pin DDR2 SDRAM 1066 PC2 8500
-----http://www.newegg.com/Product/Product.aspx?Item=N82E16820148069&Tpk=N82E16820148069
Optical Drives: 2x LITE-ON 20x DVD+-RW Sata
-----http://www.newegg.com/Product/Product.aspx?Item=N82E16827106057&Tpk=n82e16827106057
HDD: WD raptor 150gig 10k rpm Sata
Cooling:
Waterblock for the CPU comes with the kandalf case (should be enough i dont plan on OCing right away) radiator has 3x14cm fans for cooling
25cm sidepanel fan
2x 14cm rear fans
Thanks for your help and if someone knew what the blinking/pulsing meant omg i would be elated ... but once again the PC has never booted once so hmm ...
on a side note i have it plugged into a wall socket that runs my other computer fine so :S
Cooling:
25cm sidepanel fan
2x 14cm rear fans
