New Dremel owner, let the cutting begin!
Sarsbaby
Disabled
Quakertown Pa.
Yes, I took the leap and got myself a Dremel 400XPR Kit from Sears hardware for around $95.00 after tax.
Now I can mod the heck outta my case and any future cases that don't meet my specific needs as far as wire management, etc...
If you don't own one, save up and get one. They make modding so freakin' easy it's almost funny. Just make sure you have basic power tool knowledge.
I'm working on modding the right side panel of my Armor case to utilize fans for cooling the backside of the motherboard. At some point I want to mod my old Antec 900, and maybe if my current rig is ever apart, and make more management ports on my Armor case. If you need another fan port, make one! It's makes modding fun.
If your not good with tools, don't worry. They are easy to use. Make sure you wear your safety glasses though! I'm glad I went and got this.
I suggest if you are into modding, go out and purchase one. Whether it's Craftsman or Dremel, you can't go wrong. There are many household uses too.
I'll post some pic's of what i've done, when it's done.
Shiggity
Chicago, IL
Yup, I suggest getting one that ISN'T cordless too, much more power in the corded ones. Get a really nice kit too and you're golden :)
Looking forward to pics Sarsbaby.
Sarsbaby
Sarsbaby
Disabled
Quakertown Pa.
Yes, get a corded dremel you will notice much more power on them. It will make for faster and easier cuts/modding. Good luck1
Yup, it's corded. I think it's one of the newest models too.
Ok, I have my holes cut, just waiting on some parts.
Pics soon, don't worry.
Sarsbaby
Sarsbaby
Disabled
Quakertown Pa.
PICS!!!! Not too bad for my first Dremel mod.
Yahonmaizosz
Nice job!! How long does it take for you to finish all the 4 of them??
Btw, you have the same fan filter as I do.. :)
Sarsbaby
Sarsbaby
Disabled
Quakertown Pa.
Thank you! It took a couple hours total. Yeah, those TT fan filters are great.
I'm gonna have more pics up soon. I just modded my old ANTEC 900 for cable management. Also gave it good coat of Black paint and clear-coated it on the inside. I still need to do the inside of the back panel, ran out of paint. Ooops. Have to get some rubber lining for the new holes too.
I love this tool. :D Here's the Antec 900.
Sarsbaby
Sarsbaby
Disabled
Quakertown Pa.
hey that antec case are surely nice.
Thanks. Yeah, the new ones come with wire management holes now. So I thought "Why not?" It's looks a whole lot nicer painted black on the inside too.
You make me want to grab the DREMEL tool more and more..
And more, maybe a little harder too. Now faster. WAIT! You DID say Dremel right?
Sorry, JUST A JOKE!!! :eek:
