Hey guys I'm looking to build a new gaming rig but its been a few years and I'm not very up to date on the latest hardware. So here it goes:
What are you planning to do with this compuer? Please be as specfic as possible.
I'm mostly looking for a gaming setup, I will be doing some audio editing and production but I know an i5 will easily be able to handle my process and rendering needs. Some of the games I had in mind were borderlands 2, smite & diablo 3.
What is your budget?
I would like to keep it under 1600$
Does this include a copy of Windows?
No
Does this include peripherals (a keyboard, monitor, mouse, speakers, etc.)?
No
Are you from the United States or a different country? Are you ordering from your own country or from across borders?
Im from the states and will be ordering from them
Wherever you may be from, does the store that you are planning to order from have a website? It's okay if it isn't in English, we can manage.
I'll probably order from a combination of newegg and amazon
If you are from the United States, do you live nearby a Microcenter?
Sadly the Microcenter 15mins from my house closed down :[
So far this is the hardware I have gathered. Do you think this is a good setup? what should I add, remove or upgrade?
I actually originally built this on a budget of 1200$ but since I got a raise I get to add a little more to it. So please any upgrade suggestions =D
Case: COOLER MASTER HAF Plastic ATX Mid Tower Computer Case
PSU: CORSAIR Enthusiast Series CMPSU-650TX 650W SLI Ready 80 PLUS Certified
Mobo: ASUS P8Z77-V LE LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Edit: Now considering ASRock Z77 Extreme4 seems so have similar performance with CFX/SLI support, not to mention saves me a few $
RAM: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3
HD: Western Digital Caviar Black 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive
SSD: SAMSUNG 830 Series MZ-7PC064D/AM 2.5" 64GB SATA III MLC Internal Solid State Drive (SSD) Desktop Upgrade Kit
Processes: Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost)
Graphics card: I dont know if i should go with GIGABYTE GV-R787OC-2GD Radeon HD 7870 GHz Edition 2GB 256-bit CrossFireX or get a MSI N660 Ti PE 2GD5/OC GeForce GTX 660 Ti 2GB 192-bit SLI Support Video Card
After market CPU cooler: CORSAIR H80 High Performance Liquid CPU Cooler
Drive: ASUS Black SATA 24X DVD Burner
Do you plan on overclocking? If yes, do you have a specific goal in mind?
I do plan on eventually but Im just focusing on getting the hardware together.
Would you prefer the build to be particularly small?
Doesnt really matter to me, the mid tower is a good size.
Would you prefer the build to be particularly quiet?
I'm not concerned with with noise
In general, do you prefer this to be a computer that you can spend money on now and let it rest, or a box built for continuous upgrading?
I would like to be able to continuously upgrade my machne
Do you ever plan on utilizing NVIDIA's SLI or AMD's CrossfireX technologies? These features, with a compatible motherboard, allow a user to link multiple identical graphic cards together for added performance. In real world terms, this lets you buy a second identical graphics card down the line as a relatively cheap and easy way to gain a fairly large boost in performance. However, this requires buying a SLI/CFX compatible motherboard and PSU now, which may result in slightly higher initial cost.
Im open to the idea but I think I would have to get a different mobo, and x2 gpu which means more $ but like I said Im open to the idea. also does vram stack?
Thank you for reading, any feedback would be greatly appreciated!
No
No
