- Nov 29, 2007
Hi all, firstly long time no see, I love to see such old specs on my signature!
So I just upgraded from a GTX 970 to my brand new GTX 980. Deleted old drivers, fired her up, started in 800x600 (Using DVI), and once drivers were installed: Black screen.
I plugged in the HDMI and it works fine, but for some reason it refuses to see the monitor through DVI-D. Bootup and BIOS show fine, and like I mentioned, if the card is uninstalled in Windows, it suddenly outputs through DVI-D no problem. Opening the "Multiple displays" screen, the main monitor I want to use with DVI-D is not displayed.
I'm stumped, I don't know what to do, what setting the driver is applying that disables DVI-D. I need to use the DVI-D since my monitor only supports 144Hz with that cable, so I can't use HDMI or display port.
Any help? Really lost here.
ASUS P8P67 Pro
i5 2500K @ 4.2GHz
ASUS Strix GTX 980 (3 display ports, 1 HDMI, 1 DVI)
8GB RAM
Windows 10
Thanks.
ASUS P8P67 Pro
i5 2500K @ 4.2GHz
8GB RAM
Windows 10
Thanks.
