New headset time...
torin3
It appears I have well and truly lost my bluetooth headset.
I've had this model for a while: http://www.newegg.com/Product/Product.aspx?Item=N82E16875954469
Worked reasonably well, except for an annoying dropout of sound that would happen randomly and last for 1 to 10 seconds when I was listening to audiobooks.
Is there a similar style that is an obvious step up in quality, or should I just get another one?
Thanks!
Pinky
Narf City, USA
If all you need is a cheap bluetooth headset, the Samsung HM series can be found for less $$. It will probably last as long as the one you're considering replacing with the same. ;)
torin3
torin3
I was hoping for a bit more than "cheap bluetooth headset" since I use it a lot. And Samsung HM covers a lot of models.
I will be ordering something today because if I don't get a replacement soon, I'm going to start twitching like a junkie in withdrawal. (That is me, the techno-junkie....)
But $75 or less was my tentative budget.
