New heatercore shroud!
ive just realized, the holes for mounting the fans are too big :(. Im using an evercool 120mm fans, now I have to buy new screws that'll fit.
anyone know where you could buy the mounting screws that goes thru the shrouds and radiator? could you buy those at a local home depot?
Yes you could.
Ive already bought some :D. took a while to look for it at home depot, its called a Threaded Rod(#8-32), then bought some wing nuts to go with it.
I think those new shrouds attach without having to use threaded rod to go through the actual fins of the core. Anway, the size you want is 6/32 not 8/32.
Yeah that does seem a little high for shipping one item. They carry it at Cooltechnica as well. Shipping is probably nominal if you are buying a new setup.
