- May 27, 2002
- Ohio
Well, i had an SI-97. I tried lapping it in the past. i ended up bending the heat-pipes, and it wasn't lapped flat. It would never sit flat on my CPU, causing the PC to Shut-down at times.
i finially got annoyed of it, and ordered ANOTHER SI-97! ( but i got the SI-97A model, as its the only one heatsink factory had ).
Then i went to Newegg, and ordered a Vantec 92mm Tornado.
OH MY GOD!
i did not realize that those tornado fans were this damn loud! its friggin INSANE! i'm probably going to need to get a fan controller for this thing!
But the great thing is, i have a cold-air duct going to my PC. I have an 8" x 8" hole in my wall, that leads outside. There's a block of foam in the hole, with the center cut out, and aluminum foil type dryer ducting going from the hole, to a hole i cut out in the side panel of my PC, directly across from the CPU.
Well, with the new heatsink that is actually FLAT, and doesn't have bent heat-pipes, and this tornado fan, i am running at 16C temps..at MAX LOAD with Boinc running!
suffice to say, i'm UNGODLY happy. Now i just need to controll the speed on this fan, and everything will be just perfect!
though, i'm still amazed that i'm running at 16C at max load!
Now to just drain the blood out of my ears.......
OH MY GOD!
