victoroy
- Apr 23, 2015
- Monterrey , Mexico
Hi , this is my first water cooling loop , i was using a 1 Rad all in one water cooling solution , and the temperatures get little high! , when i was just surfing on google chrome the temperature reach 40 C , and when playing GTA V some times 65 C , now i order some water cooling parts from amazon and i build my own water cooling loop , the question is:
My temperature when im surfing on the web our just watching some videos is 25 C our some times 35 C , and when playing GTA V 40 C max 50 C , some friends tell me that is a little by warm , it should be 16 C not 25 .. , then i was asking my self if i just make a bad config .....
Here is my PC hardware:
2 x Samung SSD EVO 250 Gb
Motherboard: Asus Crossair Formula AMD3+
CPU: AMD FX9590
RAM: 4 X 4GB Corsair RAM
GPU: Nvidia GeForce 660
NOTE: Only the CPU is in the water cooling loop
Also other thing , I was a little out of money and i just buy Vinyl Tube from home depot (It is really hard to manage) , i dont know if that afects , also i use Destilled water and some UV Dye from XSCP
Here is my water cooling hardware:
Pump: Swiftech MCP655-B
Fans: 2 x Corsair Air Series AF120
Fittings: XSPC G1/4" to 1/2" ID, 3/4" OD Compression Fitting
Dye: XSPC ECX Ultra Concentrate Coolant, Blue UV
Balancer: Phobya Balancer 150 Reservoir - Black Nickel
Biocide: Petra's Tech PT Nuke Cu Concentrated Biocide
CPU Block: XSPC Raystorm CPU Block for AMD
Rad: XSPC EX240 2 x 120mm, Dual 120mm Low Profile Split Fin Copper Radiator
I dont know if it is normal this temperatures , can i get some help ? im new in this type of cooling
Here is a photo of the system:
Thx!
CPU: AMD FX9590
Thx!
