AMDGuy (Jul 06, 2001 08:39 a.m.):
Tacoman667 (Jul 06, 2001 07:59 a.m.):
I have water cooling and I still dont go over 25C at load. I think that the temp change it just with certain chipset revisions. I have the newer revision since I bought it only 3 months ago.
That temp seems awfully low even for water. How are you determining temp? In Socket Thermistor? Unless your room temp is below 20C and your case temp is about the same, I don't see how you can have a 25C max load die temp unless your running a pelt. I'd get one of those crazypc.com digital themometers to see what the die temp actually is. Hoot did a write up on this a while back. I implemented it and it's great.
I think this temp difference with different BIOS has to do with a hlt instruction being sent to the chip. Some BIOS revisions use it, some don't. You'd think Abit would put it in all of them. Makes no sense to me.
