New M.2 problem.
Hardass
Senior Member
I have a Rampage V. I just installed a new Samsung 960 EVO m.2 I installed windows 10 with no problem. Here is problems. CrystalDisk does not see it, Samsung Magician just shows space on it but no options to update firmware or health. Defraggler shows it as a hdd. I am running latest bios.
I would guess it is a setting in bios. I installed latest chipset driver.
psionic98
Not saying that it's not an issue, but windows and such see it just not standalone apps? Like normal windows explorer and disk management find it?
Woomack
Benching Team Leader
I would ask ASUS if they have any update as this board still gets updates from time to time and they don't have anything better on X99 anyway ( also RVE 10 but I guess they are using the same updates ). Samsung 960 is new series and I saw that some boards get BIOS update for this drive.
I had no issues with some other M.2 SSD on RVE but I don't have any Samsung.
Hardass
Hardass
Senior Member
Do I need to change any settings in bios for this ssd?
Woomack
I thought that for Samsung are additional drivers but I don't know if they're required. For my SSD are no additional drivers and they work on standard MS driver. I don't think I ever needed to set anything in BIOS. Right now my brother has RVE and he doesn't have M.2 SSD.
Hardass
Hardass
Senior Member
I just installed the latest Samsung driver 2.1 and same thing. CrystalDisk does not see it. When I go into device manager
and select ssd and go into properties to check driver version it still shows microsoft driver from 2006.
Hardass
Hardass
Senior Member
Now the controller shows the new Samsung driver, but the M.2 shows Microsoft driver.
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
So... it works just fine, boots, etc... just other apps aren't seeing it in windows?
And you have 3501 bios, right?
I don't think it's a setting in the bios...
dejo
Senior Moment Senior Member
is it crystaldiskmark that wont work or is it crystaldiskinfo. if the latter- only version 6.8 and newer will see an nvme drive.
Hardass
Hardass
Senior Member
That got it working, stiil no SSDLife and Defraggler still shows hdd not ssd options. I downloaded latest of both.
satrow
Cymru
Install and run the trial version of HD Sentinel so you can see what results that gives, if it shows Trim as enabled but not active, you probably need to change the SATA driver (though the default MS driver usually works fine but some say it might be slower than the 'correct' drivers).
http://www.hdsentinel.com/
Hardass
Hardass
Senior Member
I do not see anything about trim.
satrow
Cymru
I've no experience with M.2s but that seems to indicate that it's not being detected as an SSD. HDS version history shows that M.2/NVME was added a year ago (950 NVMe Pro M.2 SSD: detection of complete status including power on time, temperature, read/write statistics, wearout, etc.), using the Samsung NVMe SSD driver on this page: http://www.hdsentinel.com/driverzone.php (driver version 1.1).
Perhaps it cannot detect TRIM, the other stats in your image look like the SMART detection is working as expected. Percentage used (no SMART # shown) is used as the wearout/health indicator there.
I don't know what else to suggest, it looks like everything but TRIM is being detected.
TechWizard
Can you take a screenshot of what the Samsung Magician shows just for reference?
I don't know how similar the Rampage V is to the rest of the ASUS line, but I remember when I got my 950 I had to change the SATA mode config to M.2 before it recognized it. Ever since then it appears the setting defaults back to SATA Express, but the M.2 drive functions on the PCIE lanes.
There's a lot of awesome SSD tools in this thread, just sayin.
