ZachMonroe
- Mar 2, 2014
- Upstate NY
Hello Everyone, I'm new here and have been playing around with crypto mining for a little while and recently started getting ready for building a dedicated mining rig and have a couple questions about it. I have been doing a lot of reading on many forums and blogs, this has created a little confusion in my head of which way to proceed. Any help/advice appreciated.
Parts I already have ordered (should show up tomorrow):
- ASRock H81 Pro BTC Motherboard
- Intel Celeron G1820 Haswell 2.7GHz
- 4GB DDR3 1600
- 2 X SAPPHIRE Radeon R9 280X Toxic
I can get this part setup pretty easily I think, so my questions come with planning for the future. I would like to eventually have 6 - 280x Toxics in the rig.
Questions:
OS?
I was hoping to use BAMT or SMOS or *buntu on a usb drive, but wondering if I should get a small (32gb) SSD and a copy of Windows 8.1? I know I have seen several times that the drivers are better in Windows and 8.1 seems to do good with a 6 GPU rig. But if possible would like Linux. I have used *buntu variations on many other project of mine and have always liked Linux systems.
PSU?
I am leaning towards Corsair or Thermaltake. I was hoping I could get a Corsair RM1000 and use that to run the System with the initial 2 GPUs and then later add a thrid GPU. As soon as I go to a fourth GPU I would need a second PSU and was hoping a RM850 would work for the last three cards? I am planning on undervolting the cards, so would that be another reason to want Windows? If those PSUs are not sufficient then my second option would be start with two Thermaltake TPG-1200M? I would prefer to use two of the same brand PSU.
Risers?
I am planning on using USB powered Risers. I read somewhere that I do not want to use powered risers with the ASRock H81 Pro BTC, I assume if this is true then I just won't hook up the power to them and they will work as unpowered risers? Or do they need the power still to work over the extended length of the USB cables?
That is it for now, I'm sure I'll have some more questions along the way.
I am planning on building my own chassis before I get a third card, I'll just have everything sitting on a desk until then. I will most likely be building it out of aluminum.
Thanks in advance for any help/advice.
Zach
- 4GB DDR3 1600
Questions:
OS?
PSU?
Risers?
Zach
