New monitor!
Itachiii
Hey guys, I made this thread in the General hardware section by mistake and I'm moving it here. So, I'm building a new rig and i'm in a dillema of what monitor I should go to. Notice that the three monitors that I am to choose from are all at the same price in my local stores. Budget is ~350€ .
https://www.amazon.com/FlexScan-EV2...67455076&sr=8-2&keywords=Eizo+Flexscan+EV2450
https://www.amazon.com/Asus-VG248QE...8&qid=1467455111&sr=8-2&keywords=BenQ+XL2411Z
https://www.amazon.com/BenQ-XL2411Z...8&qid=1467455111&sr=8-1&keywords=BenQ+XL2411Z
Which one would you suggest? Would you go for a monitor outside the list? Thx!
EDIT: https://www.amazon.com/Samsung-UHD-...d=1467457154&sr=8-1&keywords=Samsung+U24E590D
I'm thinking of this as well! What do you think?
ATMINSIDE
Can you find any Dell UltraSharp monitors in your area?
ATMINSIDE
Sounds similar to my usage, either one will serve you well.
The UP2516D is a newer model and the panel calibrates a hair better, but I doubt you'd notice the difference between the two.
I'd get which ever of those two is cheaper when you're ready to buy :)
I
Itachiii
Thx for the help ATM :) would you consider buying the 4k Samsung I posted? If not, why not? Thx again!
ATMINSIDE
I would stick to 1440p personally, for many reasons.
Also 4K in a display under 27" is borderline useless, you get to where you can't see things well.
I
Itachiii
Ok i'll stick with one of those two then! Thx for the help ATM :)
