new motherboard and cpu
cbz5
What is the best motherboard and cpu for a total of aprox $100?
I will be doing little to no overclocking. I just want a stable system. I would like to be able to use my old sdram.
deadkenny
Toronto
newg said:
Oh I don't know....maybe a K7S5A Pro & a XP2100+...........
That would certainly be the best choice from a performance and future upgrade potential perspective. However, not so sure about stable...
If you want something that cheap, and want to use your SDRAM then you're looking at something old. For socket A, either the SiS 735 chipset on a m/b with both SDRAM and DDR DIMM slots (e.g. K7S5A) or something based on the Via KT133A chipset (SDRAM support only though) are probably your best bet. Another alternative would be something like a Tualatin based Celeron on a m/b like the TUSL2-C. Nice and stable, with decent performance but not as good performance as a socket A solution and with no upgrade path at all.
newg
Maine, U.S.A.
As far as stability.....the early K7S5A's were trouble for me but the systems I've built with the Pro's gave me no problems at all.....seems ECS improved on them a bit......
TimWest
Florida
IF you want cheap and stable.
I would get K7S5A and a 1.6 Duron. CPU + MB + Fan would be about $90.
You can still us PC133/PC100 ram. This wouldn't be a bad upgrade from a sub 800Mhz machine on a budget. IF your old machine is faster I would spend more or wait longer.
Beavis
Austin, Texas
Here's some stuff that might interest you. It's $25 over budget but thought I'd throw these out there. I've used sdram before and ddr is alot faster I think. You could sell the sdram on ebay to recover some loses.
BIOSTAR nForce2 400 Chipset Motherboard for AMD Socket A CPU, Model "M7NCD" -RETAIL for $53
http://www.newegg.com/app/ViewProductDesc.asp?description=13-138-216&catalog=22&depa=1
AMD Duron 1.4GHz Socket A Processor - OEM for $37
http://www.newegg.com/app/ViewProductDesc.asp?description=19-104-158&catalog=343&depa=1
Buffalo Technology 184 Pin 256MB DDR PC-2700 - OEM for $35
http://www.newegg.com/app/ViewProductDesc.asp?description=20-150-592&catalog=147&depa=1
Edit: Forgot to say that I'v had bad experince with the ECS K7S5A but that was an earlier revision.
