Heres the pix if you havent alread seen em HERE
Lazlo Panaflex Member Joined Aug 18, 2002 Location Mean Streets Of Orange County CA Nov 21, 2002 #1 Heres the pix if you havent alread seen em HERE
M00CH Member Joined Jul 26, 2001 Location newfoundland Nov 21, 2002 #2 is it just me or do none of the pictures work
mbentley Gloriously Lead, Overclockix Chief Architect Joined Sep 26, 2002 Location Indianapolis, IN Nov 21, 2002 #3 M00CH said: is it just me or do none of the pictures work Click to expand... they work fine for me... thanks for the direct link to that pic area.
Rav Member Joined Apr 25, 2001 Location Philthadelphia Nov 21, 2002 #4 That thing is so massive you have to make sure your other components don't get sucked into its gravity well. Is it me, or does it look like it encroaches on the second PCI slot as well? -Rav
Jawsome Member Joined Jun 24, 2002 Location Maple Grove, Minnesota Nov 21, 2002 #5 from the looks of it im pretty sure a pci card will fit in there.
mbentley Gloriously Lead, Overclockix Chief Architect Joined Sep 26, 2002 Location Indianapolis, IN Nov 21, 2002 #6 Rav said: That thing is so massive you have to make sure your other components don't get sucked into its gravity well. Is it me, or does it look like it encroaches on the second PCI slot as well? -Rav Click to expand... i think it's only the first one... they would get so much crap if i took up a total of 3... *edit: okay, now the pictures don't work for me * Last edited: Nov 21, 2002
