New PSU
I think a good 750w should work, but I'd rather stay on the safe side and get a 850w one.
Always pick good reliable brands like Corsair, Seasonic, Silverstone, Enermax, Fortron...those are the absolute best. Then other brands offer good models, but not all of their lineup is top notch -thinking Antec, OCZ, and many more-
The Kingwin Lazer Gold LZG-700 would be a good choice. High efficiency (gold rated) and low noise, price isn't half bad. It's a SuperFlower made unit. All the Platinum units out there with the right number of connectors for SLI and a decent wattage just cost too much right now.
It's modular (a negative in my books), having owned the SuperFlower Golden Green branded model of the same output I can confirm that its a nice and quiet unit.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817121077
The 1000Watt unit is extremely good value for money at $169, everything said about the 700W unit applies to this also.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817121075
Reviewed over at JonyGuru by our own OklahomaWolf: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=191
May as well go for overkill if the price is right. At only $5 more than the HX850 I'd say the SuperFlower unit is a better choice, when it comes to value at any rate.
Wow at that Kw Superflower unit! O.O
I'd consider buying one of those if I were in your shoes, -or if someday I get a second 580 or a dual gpu card-
Kind of forgot about Superflower, they make a lot of the good ones -like Seasonic does too-
