New Raid0, and BSOD's
Norcalsteve
Baker, FL
So, Lemme try to keep this simple.
My rig (in sig), Stable OC to 4.0 (i am pretty sure)
I used to run only with a WD 1TB hard drive in SATA
Now, I just installed x2 WD 320GB HD's in RAID0, and installed Windows 7 ult x64
Everything is smooth, and i can sorta "Dual boot" to either RAID0 or Regular just by going into BIOS and setting Raid or not for the respective drives until i get all my settings to and progs installed and ironed out similar to how my 1TB is set up, then i can wipe it and use it as my back up... but before i do this is what happend:
i was playing Call of Duty MW2, and i got a random BSOD 00007D 2 times in a row 10 min or so into both rounds after i rebooted back into the game... i have seen it before while overclocking, but i have not seen it since i went to RAID0, so either my OC is bad, or my RAID is bad... as we speak, i have tweaked some settings with my ram timings (back to auto) and i am running prime95 to help rule out the OC if it was an issue
But if its the HD's is it just a defunct RAID setup? I have NEVER installed a RAID before so dunno if i messed up... or am forgetting something.
Also, my computer had or still has problems going into sleep mode ever since i installed this RAID0 too, i will test that out more...
Norcalsteve
Norcalsteve
Baker, FL
Disregard, it was my OC not my RAID0... sorry to jump to conclusions and clog the forum with my incompetence!
