- Dec 11, 2003
- California
My X wife wants me to build a machine for her, this is what I came up with. It will be used for some gaming for the kids as well.
Enermax CS-3051L-S3A (Silver) Aluminum Mid ATX Tower Case w/ Enermax Logo on side Window and Sound Sensitive Neon Light - Retail.
Specifications:
Case Type: Mid-Tower
Color: Silver
Material: Front Panel Plastic, Acrylic, Aluminum; Entire case: Japanesse SGCC Steel 0.7mm
Drive Bays: 5.25'' x4,3.5''(External) x2, 3.5''(Internal) x4
Expansion Slots: 7
Front Ports: USB2.0 x2,Mic/Speaker x1
Power Supply: 350W
Cooling System: None
Motherboard Compatibility: Standard ATX
Dimensions: 19''x7.9''x16.8'' more info-> N82E16811124042 $55.00 $55.00
ABIT nForce2 SPP Chipset Motherboard for AMD Socket A CPU, Model "NF7" -RETAIL
Specifications:
Supported CPU: Socket A AMD K7 Duron/Athlon/Athlon XP Processors
Chipset: NVIDIA nForce2 SPP + MCP
FSB: 400/333/266/200MHz
RAM: Support Dual Channel 3x DIMM DDR333/266/200(3GB Max) and 2x DIMM DDR400(2GB Max)
IDE: 2x Ultra DMA 33/66/100/133 up to 4 Devices
Slots: 1x AGP 8X/4X, 5x PCI
Ports: 2xPS2,2xCOM,1xLPT,6xUSB2.0(Rear 2),SPDIF Out,1xLAN,Audio Ports
Onboard Audio: 6-Channel AC97 CODEC
Onboard LAN: 10/100Mbps Fast Ethernet
Form Factor: ATX more info-> N82E16813127144 $79.99 $79.99
SAPPHIRE RADEON 9600 Video Card, 128MB DDR, 128-bit, DVI/TV-Out, 8X AGP -RETAIL
Specifications:
Chipset/Core Speed: RADEON 9600/325MHz
Memory/Effective Speed: 128MB DDR/400MHz
BUS: AGP 4X/8X
Ports: VGA Out(15 Pin D-Sub)+TV-Out(S-Video Out)+DVI Connector
Support 3D API: DirectX®9, OpenGL®2.0
Cable/Accessories: Cables,Driver CD
Max Resolution@32bit Color: 2048X1536@85Hz
Retail Box (See pics for details) more info-> N82E16814102289 $115.00 $115.00
AMD Athlon XP 2400+ "Thoroughbred" 266 FSB, 256K Cache Processor - Retail
Specification
Model: AMD Athlon XP 2400+
Core: Thoroughbred
Operating Frequency: 2GHz
FSB: 266MHz
Cache: L1/64K+64K; L2/256K
Voltage: 1.65V
Process: 0.13Micron
Socket: Socket A
Multimedia Instruction: MMX, SSE, 3DNOW!, 3DNOW!+
Packaging: Retail Box (Heatsink and Fan included) more info-> N82E16819103336 $80.00 $80.00
2X Crucial 184 Pin 256MB DDR PC-3200 - OEM
Specification
Manufacturer: Crucial
Speed: DDR400(PC3200)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 3
Support Voltage: 2.5V
Bandwidth: 3.2GB/s
Organization: 32M x 64 -Bit
Warranty: Lifetime more info-> N82E16820146533 $52.00 $104.00
SONY MPF920 Black 1.44MB 3.5INCH Floppy Disk Drive, OEM
Specifications:
Capacity: 1.44MB
Average Access Time: 94 ms
Interface: 34 Pin Standard Floppy Connector
Form: 3.5 inch
Media Type: All Standard 1.44MB & 720KB 3.5 Floppy Diskettes
Features: High Quality and Reliability,Customized colors available
Remark: OEM more info-> N82E16821103116 $8.00 $8.00
Western Digital 80GB 7200RPM IDE Hard Drive, Model WD800BB, OEM Drive only
Specifications:
Capacity: 80GB
Average Seek Time: 8.9 ms
Buffer: 2MB
Rotational Speed: 7200 RPM
Interface: IDE ULTRA ATA100
Features: Quiet Drive technology
Manufacturer Warranty: 1 year
Remark: OEM Drive only more info-> N82E16822144102 $66.00 $66.00
Logitech Cordless MX Duo USB/PS2 104keys --RETAIL
Specifications:
Interface: USB/PS2
Number Of Keys: 104 keys+12 function keys+2 wheel
Wireless Technology: RF
Palm Rest: Detachable
Design Style: Standard
Mouse included: wireless optical
Features: Eliminate the clutter with cordless freedom, Get comfortable with the keyboard's ultra-flat Zero Degree Tilt design, Make scrolling easier with the unique iNav wheel, Ground-breaking new MX optical engine captures more data every second, Cruise Control system combines two buttons with scroll wheel, Rapid charge base station more info-> N82E16823126124 $76.00 $76.00
SCEPTRE X7g-KomodoIV 17" LCD Monitor –RETAIL
Specifications:
Panel Type: TFT Active Matrix LCD
Native Resolution: SXGA 1280 x 1024
Pixel Pitch: 0.264 x 0.264mm
Brightness: 250 cd/m2
Contrast Ratio: 400 : 1
Response Time: 15 ms (R), 10ms (F)
View Angle: 150° / 140° (Horizontal / Vertical)
Input Connectors: VGA D-Sub 15 Pin
Synchronization Range: Horizontal: 15-80kHz, Vertical: 50-90Hz
Dimensions & Weight: 18.0" x 17.8" x 8.3"(WxHxD) / 15.86lbs
Manufactory Warranty / Phone No.: 1-Year / 800-788-2878
Dead Pixels Policy: Replacement or Refund for 8 or more DEAD PIXELS ONLY! more info-> N82E16824112148 $349.00 $349.00
MSI black 48x24x48x16 Combo Drive, Model X48 black, OEM Bulk Pack
Specifications:
Write Speed: 48X CD-R,24X CD-RW
Read Speed: 16X DVD-ROM,48X CD-ROM
Interface: ATAPI/E-IDE
Buffer: 2 MB
OS Support: Windows 98SE/Me/2000/XP
Features: Anti-Bumping System Technology
Remark: OEM pack (see pictures for details) more info-> N82E16827100031 $48.99 $48.99
Creative SBS450 4.1 Speakers Retail
Specifications:
Configuration: 4.1
Power Output: 41 Watts RMS(4x Satellite Speakers: 6 Watts/channel;1x Subwoofer:17 Watts)
Frequency Response: 40Hz-20kHz
Signal to noise ratio: >=75dB
Remote: Wired Remote Control
Features: wired remote control that can be placed anywhere on your desktop for convenient and easy colume/power control more info-> N82E16836116132 $39.00 $39.00
Subtotal » $1,020.98
Specifications:
Color: Silver
Expansion Slots: 7
Power Supply: 350W
Specifications:
Specifications:
BUS: AGP 4X/8X
Specification
Core: Thoroughbred
FSB: 266MHz
Voltage: 1.65V
Process: 0.13Micron
Socket: Socket A
Specification
Cas Latency: 3
Bandwidth: 3.2GB/s
Specifications:
Capacity: 1.44MB
Form: 3.5 inch
Specifications:
Capacity: 80GB
Buffer: 2MB
Specifications:
Interface: USB/PS2
Specifications:
Specifications:
Buffer: 2 MB
Specifications:
Configuration: 4.1
