- Jun 13, 2005
I had a lot of fun making my other two rigs, and they've served me well. Here they are:
http://www.ocforums.com/showthread.php?t=399997
http://www.ocforums.com/showthread.php?t=406645
I have a new project and I'm going to document (sorry for ****ty pics, can't find the digi cam so cell must do for now), here's the scope:
Lian Li a70a full tower case. 4x120mm intake fans, 4x120mm exhausts (3 via topmounted radiator). The rad fans will be Scythe 1900rpm ss's.
Planned hardware is Wolfdale e8400, evga 780i, 2x 9600gt's (to be upgraded on the 9900's release), OCZ 2x2gb pc8500
Swiftech 655 pump, apogee GTX CPU block, ?? GPU block. Also a reservoir with some passive cooling capability.
With that much air flowing through the case, passive cooling will be paramount. MOSFETS, NB + SB and ramsinks will all be passively cooled, as will the video ram likely. I haven't looked into full block gpu coolers for sli g92's, but since I plan on upgrading to the 9900, I'd like to keep it simple for now. Will likely use 2 DD Maze 5 blocks.
Current issues:
Pump mount location (likely bottom)
Flow Order
Cooling the SLI'd cards
I'm shooting for this rig to be fully benched and tuned by July. A couple paychecks stand in my way.
Here's some images of my progress with the case modification:
Current issues:
Flow Order
