had problems with the koolance 402x2 ( could not get the air out or stop it making millions of little bubbles) so now using the koolance 452x2 with two XSPC / Laing D5 Vario Motor pumps remade some pipes to fit to new res added two home made fill ports bleed ports. still on going hope to be done very soon
in the process of building a new rig to be cooled by a flash cooler.
the bits
Asus Rampage IV Extreme Motherboard Core i7 2011 X79 Extended
GSKILL RIPJAWS Z SERIES 2133 CL 11.0 8GB MEMORY RAM RED DDR3 XMP CERTIFIED
Intel i7 3960X 6 Core Extreme CPU LGA 2011
evga hydro 680 gtx
ek cpu block
ek mother board block kit
seasonic 1000 xp platinum
koolance rp-402x2
2 x ddc laing pumps
16mm od pipe xspc
for joining to the flash cooler
xspc g1/4 to 16mm compression fittings 8 x
ek hd tubing
ek hd tubing fittings g1/4 x 20
mayhems pastel red fluid
mayhems pastel ice white fluid
lamptrons cw 611 fan pump controller
2 x koolance inline flow meters ins-fm17 with frequency adapters
2 x phobia in line temperature sensors
1 x ocz ssd drive
1 x Seagate hybrid ssd drive
1 x Samsung hybrid ssd drive
1 x corsair 800d case
1 x dual loop beer flash cooler
4 x quick disconnects
1 x dvd re writer
1 x knight rider style hdd meter
this will be running as a dual loop system one red one white
still adding bits ( going to bankrupt me I think)
going to add a complete single sleeve psu cable set
added a couple of pics of it so far any suggestions still got lights to do and install windows on it and then set profile in pump controller and woo hoo hopefully let me know what u think will add more pics when ive done more just waiting for a price on a single sleeved braid psu cable set then should be able to finish this will be adding the led's this week
right changed the case as I did not like it to the coolermaster haf x and modded it. changed the koolance rp-402x2 to the newer one and added the rp 401x2 because added a third loop also added mayhems blue berry coolant painted the case to my preference and changed the cooler to a multi product one ie can have four cooling loops also added the braided psu cable set also changed the size of memory to 16gb quad set still the same specs and changed all fittings from ek ( horrible fittings) to barrow compression ones. changed the pumps on the rp 402x2 to the koolance PMP-450S. on the 401x2 have a standard laing ddc 10 watt also change the graphics card to the evga hydro copper gtx 780 and put two usb 3 ports on the front of the case near the bottom and changed the boot drive to the Samsung evo ssd and generally tidied it up just have the side to mod and fit a window hope you enjoy the new pics ps its rapid
the bits
evga hydro 680 gtx
ek cpu block
koolance rp-402x2
2 x ddc laing pumps
16mm od pipe xspc
ek hd tubing
1 x ocz ssd drive
1 x dvd re writer
