New system
Maceox
Can someone explain why the classified board is much more expensive? Is it worth the price boost? I will be running 2 X 260 Sli and an i-7 920 cpu
EVGA E758-A1 3-Way SLI (x16/x16/x8) LGA 1366 Intel X58 ATX Intel Motherboard - Retail
Core i7, 3-Way SLI & Crossfire Ready, E-LEET OC Utility(limit 5 per customer)
$249 after rebate
EVGA E760 CLASSIFIED "Overclocker's Pick" 3-Way SLI + PhysX 1366 Intel X58 EATX Intel Motherboard - Retail
3 Way SLI, Digital PWM, E-Leet Utility and Vdroop control(limit 5 per customer)
$374 after rebate.
J-O_S-H
England, United Kingdom
$249 after rebate
$374 after rebate.
Classified is only worth it if you are benching with extreme cooling or can actually take advantage of all the PCI-E slots.
If you want to spend that much on a motherboard I would reccommend the ASUS Rampage II extreme... or even the new gigabyte UD7 with SATA + USB 3
fire2havoc
California
Classified with the NF200 is only worth it if you're going to use watercooling. Otherwise, it's more than the typical user will need. The EVGA E758-A1 is a very good board and shouldn't limit your system in any way.
