New Tbred w/ DLT3C?
does any1 here have a week 310? kuz i wanna know for sure if weel 310 is also a "wonderchip" or if its the standard POS .... i wanna know real fast too, kuz i ordered 3 of them
Well, I have one, but I'm not installing it until the end of the week when my WC is finished.
It has the reflective white on the core, which according to the 1700B guide means it OCs well :D we hope ;)
I just got my XP1700 (JIUHB:0307VPMW DLT3C)
Happy so far with my 1 Gig OC.
Still need some more though...
wow nice! got one 0307vpmw at ups waiting for me to clear it at customs tomorrow. Can you answer me this:
how high can you oc it with 1.8v or less with prime95 solid?
I just gave away to my friend today my dut3c 0308mpvw that will do 2412 @2v prime95 solid but too hot to run like this in the summer. It does 2200 @ 1.8v Solid P95
Thats why I try my luck with DLT3C 0307VPMW
I am not sure what it will do at 1.8v - I have not tried yet.
I do know mine does 2310 (11 x 210) at 1.675v.
I will try 1.8 later tonight....
my 0310XPMW can do 12x181 prime95 stable at default vcore
Right now i'm at 12x193 at 1.625 vcore with prime95 runnin steady for the last 10 hrs. temp at the moment is 41c.
pretty shure this chip has a lot left in it.
these are some awseome chips, I could only get my 0301 2100 to 2.14 stable and that was with 1.8 volts
thats what its at right now with prime95 running and surfin.
using a tk volcano 7+ on the medium setting.
0310 UPMW 12x 213mhz @ 1.9V Water cooled temp according compunurse is 28.3C full load prime95. Room amibent temp 24C.
Not bad! :cool: I also have an 0310 UPMW, which doesn't get tested until Friday :(
Seems that it doesn't OC as high with low voltage but it OCs very well with high voltage.
Sounds like it's perfect for watercooling :D
AMAZING! thanks gb5766
That is what I am shooting for! Should have it by noon :D
Need some low voltage DLT3C lovin
:p
I got the XPMW core running at 2400. It runs at 2000 with default voltage. WOW!!! This is awesome. That's almost a 1Ghz overclock. These things rock. Posts all the way up to 2550. I'm sure I could get it up higher with better cooling. I'm just using a crappy volcano 9.
Very nice, with the same core and a Tec I was able to run @ 2200mhz, 1.4v. I am now stable @ 2400, 1.6v.
im going hunting for one of these babies at the markets (aka swapmeet, whatever) i hope i can find a good one! :)
got the 0308XPMW ..... 2.3ghz at 1.7vcore prime95 stable with 55C to 62C load (8K3A) ....... i think my PSU craps out when i try [email protected] ...... and i'm almost sure it's not the autotempshutdown ...... it just simply gives in when i try running prime95 ....... damn generic 300w PSU !!!!
