New Tbred w/ DLT3C?
hey guys....
i have 0309UPMW xp 1700
for 1.6v i can do 200x11.5 without any problem
now i am looking for the max that i can get..
btw, i have 3x256 rams on dual channel
so that may limited my ocing...
i will post later...
good luck...
hikoshu said:
hey guys....
good luck...
I want !!!! I can boot upto 2200mhz, but locks before completely loading windows :mad:
OC Detective said:
Precisely - anyway how could a piece of software have inside information into AMD's manufacturing to know that a certain chip was downgraded! Somebody yesterday had their chip downgraded from an XP2500 - pretty clever considering it was a Tbred.....................
Maybe they downgraded the cache too. ;)
All I can say about these chips is wow. I'm definitely springing for one.
Yes, Yes, Yes!!!:D
Today, I got my order, that I placed 2 weeks ago and what I got, is:
1x brown 1700+ JUIHB DUT3C 0302 WPMW
3x green 1700+ JIUHB DLT3C 0308 RPMW
Hope they'll clock like hell!:mad: :D
BTW, as my crappy Albatron KT400 board can't reach any FSB higher than 180 MHz, while maintaining a stable operating environment, I'll soon get me a Abit NF7 Rev.1.2 and 2x 256MB of the brand new Twinmos PC3700 RAM!! This system will rock, if one of these above mentioned Tbreds can reach 2,5GHz or more! Well, a Radeon 9500 is to come too. I nearly forgot!!!:p
Celemine1Gig said:
Yes, Yes, Yes!!!:D
Where did you place your order for those 3 DLT3C?
I ordered 2 for my dually. They are from week 7 though, but I hope they work well with my watercooling... It will be a change after this xp1600 pos that does'nt overclock at all... :D
Emericana said:
i dont buy the whole "reject" cpu thing whether it was a 2800+ reject etc i just dont buy it.....
Well, I don't completely trust that program Ed reviewed on the front page yesterday, but it's common knowledge that AMD's lower clock speed cpus are really leftovers that didn't make the cut to be one of their faster models.
I just got two of these...
AXDA1700DLT3C
JIUHB 0308SPMW
Zapped all of the L3 and reconnect first two pair to make it 17*133MHz (my A7M266-D can only go upto 145MHz)... reconnected last pair of L5 to make it SMP-able... should be a major upgrade over my Duron 1333MHz (133MHz*10 oc from 1200MHz)
To those who lives in Toronto, Canada, I got it stright from a supplier, all the newer stock should be the DLT3C kind, even for 1800. Sales-rep told me that there are planty of these chips... to those who wants to upgrade, and not in a rush, could save a couple bucks when tthese chips are everywhere. I paid CDN$84+tax for each, which is ~US$50 (V.S. US$69 to US$79 i have seen on the web)
That's all for now, I will update when I got home.
AXDA1700DLT3C
JIUHB 0308SPMW
Tell us how it goes. I can only select multipliers up to 12.5 on the MSI k7d, and I'm not quite sure what I should hardcode them to...
I hard-coded it to 17x (according to ocinside.de) because 17*133MHz = 2266MHz (XP 2800+) (and DLT3C should be able to do this safely)
17*143MHz = 2436MHz (XP 3000+) (my A7M266-D can only do 145MHz safely... MAX)
and I can easily erase the second trace and make it 18*133MHz which is the offical XP 3000+ clock speed (less the 133MHz FSB) just in case any of my hardware won't hold...
Still at work... haha... kept thinking about my CPUs today, can't wait to get home...
:p
xtrmeocr said:
are these tbred A's? i read in another forum that the DLT3C is a tbred A. truth or not
mine are both Bs... there is an easier way to tell Tbred A or B, I dunno why no one seems to use it... on all of the AMD CPUs, there is a 5 digit code on the CPU board...
Palomino = 27111
Thoroughbred A = 27178
Thoroughbred B = 27291
Barton = 27488
hope this helps.
Palomino = 27111
Barton = 27488
hope this helps.
No offensive.. I just check my 1800+ AUIGA have 27291. dunno why? :confused:
The revision code will tell the stepping with 100% certainty (JIUHB, etc). The 1700+ comes in "A" and "B" flavors now with the same stock voltage/specs, which is why they're both listed as DLT3C.
