- Mar 14, 2003
- Beaverton, OR
has anyone use this chip at any voltage over 1.85V at all??? input please!
Tbreds are hot for their clock speeds and their decreased size/surface area to transfer heat to the heatsink.
poopygood said:the white label with the barcode is most likely from the company you bought the chip from. I know newegg.com uses the same white labels w/barcodes...
phobix said:I just picked up my cpu and it reads the following on the black AMD label:
AXDA1700DUT3C
9728686272466
JIUHB0308WPMW
Here's the catcher, there is a white label on the chip that says" Warranty void if removed" with a UPC bar code label and it lists the first sequence of the chip ID as:
AXDA1700DLT3C
Could this be an error on AMD's labelling process and they stuck a label on after the fact indicating the true operating voltage of the chip meaning this chip is actually a DLT3C and not a DUT3C as denoted on the black label?
phobix said:Just called AMD support to confirm the label thing....It turns out that it is a DUT3C One thing I must say, man they are really nice at AMD, the girl was super nice with me on the phone, kinda of sexy if you ask me, it sounded like a hot chick and she started talking about core voltage it made me all excited :lol: . I dunno, but it is worth a try to see if this $60 CPU Can take out my $100 XP2100+. I still want a DLT3C though
phobix said:Not too shabby for a 1700+ DUT3C, but I still would prefer a DLT3C cause of the lower voltage.
Shade00 said:Methinks it's not aircooling due to the massive vcore being pumped through there, as well as the afore-mentioned temp. What cooling are you using phobix?
tediber: That's awesome! I think one test I'm going to do when I get mine is see exactly how low it'll undervolt at stock speeds.
tediber said:DLT3C JIUHB0308 2ghz with vcore undervolted to 1.42volts using a crappy heatsink fan ..... really nice chip .... can't wait to watercool this baby
