- Feb 20, 2008
- The land of Oz
Still much to do/ upgrade, but i'm done with it financially until this fall when I plan to upgrade the PSU and video card. I just wanted some different aesthetics so added a few things. I'm not happy with the wiring and plan to redo it and move a lot of the wires behind the motherboard for the time being. I'm getting a modular PSU later, likely presleeved. I know I'm new to this, so probably looks terrible to most of you experienced guys, but hey, I still am having fun with this and enjoy the current outcome of it.
Here's how it looked before, pretty boring:
Though I did add the wireless card the night I got it.
Also added a silicone case fan vibration dampener (uv blue) to my OE 92mm fan... you can see it peeking out around the edges of the screen:
Needs a window in this door panel....
Here's the goods to do the deed:
Ready for surgery:
Sleeved the fans and lights properly with real sleeving (uv reactive blue) and for the PSU I used ez-sleeve (uv reactive blue) since I don't have the tools to dissassemble the molex or SATA connectors. Tied that up with zipties (uv reactive green) and tried to promote more airspace for better flow inside the case. Also added an LCD temp display (white LED) with temp probe to view ambient case temperature. More of an aesthetic knick knack than anything, but it was cheap and looks cool. Was going to cut one of the HD bays up to recess it but opted to leave that in tact and use double sided tape to mount it behind, hiding the wiring and the temp probe, but still viewable through the window. As far as lighting goes, it's a FrozenCPU 30 LED hyper light strip in blue mounted at the top of the case, and a clearenced out Vastech cold cathode kit (UV ultraviolet) mounted on the bottom of the case from SVC ($1.99... woot!)
Ready for surgery:
