New to computer modding, tried my hand and had fun!
the803
Wow...brilliant...
How did you make the side case windowed? I'd like my Coolermaster Elite 330 to be windowed!
S
S14sx2nr
The land of Oz
Well done the window looks much better and the LCD temp was great too have you any info on that mod too
can someone give me a link to a temp lcd just like that one
Info can be found here:
The SerialATA to molex 4pin adaptors, 92mm silicone case fan dampener (uv blue) and temp display were purchased from http://www.performance-pcs.com
Round 2 should be here tomorrow.:soda:
Specifically (if this works, it's under Electrical Case Acessories, at the bottom) http://www.performance-pcs.com/cata...th=392&zenid=01c5f94ca177b243535894906ed97187
They're $8.95 ea. and they have White, Blue, Red, Green and Yellow.
:thup:
S
S14sx2nr
The land of Oz
Wow...brilliant...
I bought a window kit from www.FrozenCPU.com and after figuring out exactly the best place to put the window and tracing it using the kit's contents, I cut it out with a dremel (until the motor finally died from years of use) with a carbide cutting bit and finished up with a jigsaw which cut through that thin steel like a hot knife through butter.
Your in luck too... FrozenCPU just offered a new 10% discount code in the vender discussion forum here: http://www.ocforums.com/showthread.php?t=538027&page=3
:thup:
