OK I'm a new to this even if I have been working with computers for 27 years.
I have just put together a new system, its not earth shattering but its not bad. I run a Gigabyte GA-7N400 Pro MB with an 2600+ chip.
My question is at what point should I worry about the core temp of the AMD? The spec says 80d C is its top limit, I know the cooler the better but how cool is cool.
I have the standard cooler fan and heatsync on the AMD and have fitted a case fan. The chip is running at 70d C after I whacked up the multiplier on the motherboard.
Do you experts think this is too high?
If it is what can I do about it?
Will moving the system fan around and therefore altering the airflow inside the case make a difference?
