Sims Reaper
- Jul 9, 2013
- Alberta
First off,
Hello all, this is my first post on the site, though I'm sure I will become a regular. I've browsed the site for the last week or so, gathering ideas for my system. I was up in the air regarding a few things, but finally, after a stressful day at work, I just up and pulled the trigger on the buy. A little pc upgrade stress relief if you will
I wanted to post it here, because, it was somewhat of an impulse buy, and I would honestly like your opinions on it. As well as advice on the whole build and mod project, though I may have to start a new thread there, because I will be modding my NZXT Phantom case for the new system. So, your thoughts, questions, queries, concerns and criticisms are welcome here!
Sound Activation Cold Cathode Addon w/ Blue LEDs
Logisys Dual 12" Cold Cathode Kit - Blue
Black Ice GT Stealth 360 X-Flow Radiator - Black
Noiseblocker NB-BlackSilentFan XL2 120mm x 25mm Ultra Quiet Fan - 1500 RPM - 21 dBA
FrozenCPU Superman Applique (I'm a Supe fan, what ca n I say, Plus my last name starts with an S so it fits )
Alphacool VPP655 Variable Speed Pump - HF Top Edition - Acylic
XSPC Razor GTX Titan Full Coverage VGA Block - Reference Design
Backplate: XSPC Titan Backplate
Swiftech Maelstrom 5 1/4" Dual Bay Standalone Reservoir (Maelstrom)
XSPC RayStorm High Performance Acetal CPU Liquid Cooling Block - Intel (Sockets LGA 1155 / 1156 / 1366 / 2011)
EK EKoolant Premium Liquid Cooling Premix Coolant - 1L - UV Blue
1/2" ID - (5/8" OD) PVC Clear Tubing
So there you have the jist of the purchase, no it was not cheap... but I'm pretty pumped about it. I have always wanted to go H20, but just never pulled the trigger. I also have nickel plated compression fittings, and uv red sleeving, with uv blue heatshrink with this, to go with the whole supermanish scheme.
So, how does it look so far.
P.S. I already know I will have to mod the case for the triple rad, its all good, going to add windows as well right away, possibly tonight. Never done any of this before so wish me luck. I'll keep you updated if you want!
Keep your sticks on the ice!
