New to me connections now, the motherboards have an 8-pin connector and a 4-pin
RJARRRPCGP
The usual 8-pin connector, plus a 4-pin connector for the CPU now! What should I get for a PSU?
(Was wondering, in case I do another build)
My Crosshair VIII Hero has this. It says the 8-pin is sufficient to run the MB, but the 4-pin (in addition) they recommend if you intend extreme OCing under cold like LN2 or something.
I ran into posts saying the same kind of thing, too.
I'm not going away from AMD, but I just ordered the parts for an Intel 10th gen hex'er build! ;)
8+4 pin EPS connections have been on motherboards for several years/generations. You see just 4-pin on some cheap models (rare). Sometimes 8 only...sometimes 8+4 or even 8+8.
Per usual, the 8-pin is required while the 4-pin is optional.
can concur.
i even have one with 2x 8 pins + 4 pin, and another with 2x 8 pins.
I built it some nights ago. It POST'ed and just like the B450 Tomahawk, IIRC, the BIOS gave me the message about the CPU being changed and asked me if I want to load the defaults and I did. BIOS looked totally normal after that.
can concur.
Well the new PSU I got, has one for a "second" CPU. Looks like I should be all golden!
