SOLVED New to the Green-no scaling adjustment?
Alaric
Satan's Colon, US
My AMD software had a scaling adjustment for my display and it was easy to find. I need it and the disc that came with my card doesn't have it. It's bad enough that I'll have to go back to my old card if there's no solution.
And what do I need to open a .rar file if I don't like 7zip?
Janus67
Benching Team Leader
Scaling of what? Do you mean for higher resolution than your monitor supports? It's under the 3d options to turn on dynamic resolution I believe and the smoothness set by a multiplier. Otherwise if it is just windows scaling that can be done via the display settings in Windows.
Alaric
Alaric
Satan's Colon, US
No, with the Radeon software I could scale down the size of the desktop to fit my display (-5% I think). My icons are hanging off the edge and windows are too big for my screen. There was a simple slider in the Display tab.
Automata
Destroyer of Empires and Use
It sounds like your monitor is doing overscan. Disable the setting on the monitor instead of the computer, otherwise your video quality will suffer.
Alaric
Alaric
Satan's Colon, US
I don't have an overscan setting. All I have for the display is Auto Aspect and that makes no difference on or off.
update: Found it. Didn't know about the NVIDIA Control Panel. It lowers my resolution a little, but everything fits.
Jeff G
Check to see if it's set at 59hz vs 60hz. My old HTPC did that all the time. If it went to 59hz, icons went over the edge. 60hz and it was perfect. Easy to check if that's it.
