It was suggested that I create an account to get more help in what I can do to get my computer up to the specifications needed to upgrade it and get more feed back into what I can do.
Right now I am trying to upgrade my graphics and it was suggested that I could most likely buy a graphics card and could in theory slide it into the slot provided, but knowing my inexperience to these things I wanted to make sure that I bought a compatible graphics card and with little luck i have the best response I have been given is "It depends on the motherboard having a PCI-Express x 16 slot available." and unfortunately before I could get more information the thread was locked as solved. which is how I stumble onto this website, because I wasnt going to give up that easily.
currently I'm using a AMD APU A4-6300 Dual-Core(https://www.pc-specs.com/cpu/AMD/APU_A4-Series/APU_A4-6300_Dual-Core/1238) and would like to see if MSI - NVIDIA GeForce GTX 1650 SUPER 4GB GDDR6 PCI Express 3.0 Graphics Card is compatible with mine.
Specifications.
OS Name Microsoft Windows 10 Home
Version 10.0.18363 Build 18363
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name DESKTOP-PKBSMN9
System Manufacturer MSI
System Model MS-7721
System Type x64-based PC
System SKU To be filled by O.E.M.
Processor AMD A4-6300 APU with Radeon(tm) HD Graphics, 3700 Mhz, 1 Core(s), 2 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. V8.2B2, 9/28/2015
SMBIOS Version 2.8
Embedded Controller Version 255.255
BIOS Mode Legacy
BaseBoard Manufacturer MSI
BaseBoard Product A68HM-E33 V2 (MS-7721)
BaseBoard Version 9.0
Platform Role Desktop
Hardware Abstraction Layer Version = "10.0.18362.752"
Installed Physical Memory (RAM) 16.0 GB
Total Physical Memory 15.2 GB
Available Physical Memory 11.6 GB
Total Virtual Memory 17.5 GB
Available Virtual Memory 13.4 GB
If you want to see a horrible example of what I bought its https://www.amazon.com/CybertronPC-Patriot-Gaming-Desktop-Discontinued/dp/B00D1KX2M4?th=1
except i went for the windows 10 as the os and for some ungodly reason is has 1 fan in the front and a water cooling system over where I can only assume the actual chip is. If need be I can move past my embarrassment of it all and give pictures as to how the inside looks for more references.
Specifications.
SMBIOS Version 2.8
BIOS Mode Legacy
