baloothebear
- Aug 10, 2016
Hello,
i just build my first custom water loop and am seriously disappointed by the result. And im looking forward to getting some feedback from more experienced water cooling users.
So first of all, this is my water cooling setup that i got used from ebay:
-Hardware Labs Black Ice Lite 360 Radiator
-Aquacomputer XT Advanced
-Bitspower 150mm Water Tank
-EK Water Blocks EK-Supremacy - Acetal+Nickel CPU Kühler
-3 x Noiseblocker Black Silent Pro Fan PL2 attached to motherboard. In Push configuration
I am currently only having the CPU in the loop, no GPU so far.
My CPU: i5 [email protected],3GHz and 1,23 V
This is the overclocking setting which I set up when still using air cooler. My core temps went up to 98° under LinX/Prime95. So way too hot for benchmarks but completely stable in games.
Now I was hoping too seriously reduce these load temps when switching to water cooling, especially when having a 360mm radiator just for the CPU.
With my first build, the core temperatures went up to 92° with distilled water in the loop. So I drained it the next morning, checked for residues (water was totally clean). I then removed the "anti cyclone" adapter from the reservoir thinking that it inhibits water flow. I also reapplied the thermal paste and reseated the CPU block. Now the temperatures for the cores still reach 82° and the CPU temp readout from AIDA64 says 68°.
Now my question is, if this is all I can expect from this setup or if there is something wrong. Temps of 82° for the core seems way too high for me with this overclock.
Any tips on how to lower the temps? Is it worth investing into a flow meter to see if this is an issue?
I can take some pictures of my setup if that helps you out. Though be warned, my hard tubing skills for my first build ever really su**ed :-D
