Alright...it's finally planned. Here's the final parts list. I plan on ordering in the next day or two.
PLEASEPLEASEPLEASE tell me if there's something I'm forgetting, or a huge mistake I'm making somewhere in here, but I think this is it. If you see anything at all I'll also need, please tell me, as I'd much rather order it now than realize it's missing and have to wait two more weeks until the other parts are past their 30 day DOA returns...Thank you to everyone who has been so much help in planning out this monster, I never would have even considered watercooling without the huge and helpful forum support base out there. Special thanks to Ecelctic (with all the nice pictures), Conumdrum (who apparently lives somewhere in for OC forum servers, or at least never sleeps), Tarnumf and MrLinky, and Namtaro on the forums I've posted this on)
This will be sooo fun to put together - and hopefully one of the quietest computers I've ever made...my only worry is leaks...
Loop 1: Pump->T->CPU->Rad->Res->pump
Loop 2: Pump->T->GPU1->Rad1->GPU2->GPU3->Rad2->Res->pump
(I hope I have enough space between the cards - if not, it'll have to be all 3 gpus, then the two rads)
Airflow: 12 radiator fans (side) pulling air into the case, 2 front fans over the hard drive bays pulling air into the case, 12 fans (5 back, 4 front, 3 top) pushing air out of the case (Yes, the front has 2 fans pulling and 4 pushing, but it's probably not a huge deal.)
Processor: Intel 980X
Case: Mountain mods Ascension CYO
MB: ASUS Rampage III Extreme (overclocks as well as the Classified, and I'd rather have USB 3.0 than dual gigabit, since that's really the choice it came down to)
PSU: Antec TPQ-1200 1200W
RAM: 2xTrident 3x2GB Trident DDR3 2000 (12 GB total @ somewhere between 1600ish-2000ish)
Video card: 3xSapphire 100281-3SR Radeon HD 5870
Audio card: ASUS Xonar Essence STX PCIe
Hard Drives: SSD + 2xRaid1 2TB HDD
Optical Drivesx2
Pump: 2x Swiftech MCP655
Reservoir: XSPC Dual Bay Split Reservoir
Radiator: 3x Thermochill PA 120.4 with 15mm spacing
Radiator fan (CPU loop): 4xScythe GentleTyphoon D1225C12B5AP-15 1850 RPM
Radiator fan (GPU loop): 8xScythe GentleTyphoon D1225C12B3AP-13 1150 RPM
Other fans: 14xScythe GentleTyphoon D1225C12B3AP-13 1150 RPM
Fan Controller (CPU loop): Scythe KM01-BK "Kaze Master" 5.25" Bay Fan Controller
Fan Screws: Acousti Black Fan Mounts (noise control)
Tubing: Primochill PrimoFlex Pro LRT 1/2" ID x 2/4" OD UV Blue
Clamps: 3/8 to 7/8 (9.5mm to 22.2mm) Clamp Dia., 1/2 Band, SEA #6 Hose Clamps, Stainless
Barbs: Danger Den Fat Boy 1/2" OD G 1/4 fittings
CPU Block: EK-Supreme HE High Flow Copper
Coolant Additives: PTNuke + 1 oz silver bar per loop (in reservoir)
Card Reader: 3.5" bay reader in 5.25" bay
Other: 4xEvercool Black 5.25" Drive Bay One Touch Spring Loaded Storage Box - same price as MM bay covers, and more useful.
Thermal Paste: OCZ Freeze Extreme Thermal
Thermal Pad: Cheapest I can find (in case I need some for GPUs)
Pump base/mounting: 2xGelstuff (pumps unmounted, on Gelstuff for noise control)
Speakers, Keyboard, mouse, mousepad, DVI cables, Ethernet cable, monitors, active DisplayPort adapter...
Video Blocks: 3x DangerDen 5870 Water Block with 1xXfire fitting kit
Mounting: Velcro cable ties, cable ties, velcro tape, 4x fan extension cable (cpu radiator) 6x molex extension cable (other fans, just in case)
Cold cathode kit: Blue (Apparently the UV coating in the tubes dies fast, but blue lights look almost as good
PSU Noise control: Vibration pad (apparently switching out the PWM fans is bad)
Rubber HDD screws (more noise control)
Tline: 2x Delrin Tee with DD fittings
Empty port: 3rd T connection fitted to 6 inch hose with a disconnected VL3N quick disconnect on the end - will plug in the other end (with attached hose) when it's time to empty the loop.
(Crossposted to all the various forums I've asked for help on
