captsulu2004
- Mar 1, 2018
hey guys. It's been a long time since I have visited this site and with me wanting to actually do a water cooling loop in my new system I thought it be a good idea to stop by here and ask you professionals some questions. Being my first ever custom(semi custom) water loop, I want to start out with this kit here, http://www.performance-pcs.com/modm...-cooling-kit-featuring-ekwb.html#!prettyPhoto.
I will not be adding VGU cooling at this point, I will expand that sometime in the future. Now on to the questions. What do you guys think of this kit as a starter kit? What would you recommend to buy along with this kit as far as extra fittings, expansion fittings, fill/drain, etc. And most importantly, what of all these extra parts should they be made out of? I hear so much talk about the whole "mixed metals" thing but I am always confused by this idea simply because you cannot avoid mixing metals. The rads are made up of aluminum with brass inserts and most pumps are made up of various metals internally. I would also like to know my best option for connecting the pumps power. I see you can direct connect with molex, use a MoBo header, etc. If it's easier for you to judge, I have the ASUS X-99-A MoBo running a Intel Core I7 5820K and 16gb's of G.SKILL Ripjaw 4 Series (PC4 19200) running quad channel. I am running a mid level Nvidia GTX 970 and customizing this with water cooling isn't exactly straight forward. I haven't found a prefab'd water block for this card. This is why I will be waiting to water cool the GPU.
Oh and what type of coolant should I use? Do they make the coolant all-in-one with the biocide, anti corrosive, and color all in one? if so, which would be the best to use? If there's anything else I should know or do that I haven't brought up here please do let me know. When I build this loop I want it to go as smoothly as possible. Thanks guys.
