- Dec 19, 2000
Instead of the normal wire trick for vid pinning why not use a conductive pen to connect the pins on the cpu or from the back of the motherboard. The wire trick is ok but its not permanent. This way you can mod either the chip or board without having the wire job fall off if you remove the cpu. I am about to get my P4 rig up and running so I might give this a try. I just need a conductive pen now. Any thoughts?
