- Mar 22, 2002
- Hartford, CT
New water coolling idea?
Just thinking about a better way to watercool. What if you constantly have fresh water running thru the waterblock?
I figure I can use 3/8 tubing, two pipe tap valves, a thermostat, a water solenoid valve and a pressure regulator.
Find a hot and cold pipe, tap into them, run the hot and cold lines into a mixing valve or just a tee (adjusting hot and cold to make water not too cool so no condensation forms) to a regulator, from the regulator to solenoid valve into a waterblock. Water flows thru and out to a drain.
The solenoid valve will run off the thermostat only letting water flow when needed. I could swing this because there is a drain in my basement and my computer is on the first floor so I could just do all the plumbing up thru the basement ceiling.
It would be much neater to have just a waterblock and two tubes.
I'LL LET YOU KNOW HOW IT WORKS OUT!
